Contact: 1.800.266.7798
Upcoming Webinar
Ignition Edge: Simplifying the Edge of the Network
How to Extend Your Network Without Extending Your Budget
Tueesday, March 28, 2017
9:00-10:00 AM PDT | 16:00-17:00 GMT
Inductive Automation introduces Ignition Edge, a new line of lightweight, limited, low-cost Ignition products designed specifically for embedding into field and OEM devices at the edge of the network. With Ignition Edge, it’s easier and more affordable than ever to extend Ignition all the way to the edge of your network.
In this webinar you’ll learn how to use the three new Ignition Edge Products — Edge Panel, Edge Enterprise, and Edge MQTT — to create local HMIs with client fallback, synchronize data to a central enterprise server, publish field-device data through MQTT, and much more.
Learn about:
• How to use Edge to access data from PLCs and OPC-UA servers
• The flexibility Edge gives you to build scalable enterprise architectures
• How you can use Ignition and Edge MQTT together to build a complete end-to-end IIoT infrastructure
• How to prevent the loss of field data with local client fallback and store-and-forward functionality
Don’t miss this valuable presentation. Register now by filling out the form on the right!
Learn about:
